Palworld – How to Fly on Nitewing Early Game – Super Easy Guide
Wazzup Everyone, Welcome back to another video guide on how to fly on nightwing in Palworld.
The first step is obviously to catch a nightwing. Open your main menu by pressing “tab” on your keyboard, then navigate to the Pal Deck section. Scroll down until you find nightwing, which is number 38 on the Pal Deck. Press the number 3 on your keyboard to locate where you can find Rightwing in Palworld.
Now, let’s head close to the area where you start the game to catch one of these pals for ourselves. If you don’t find one right away, just keep walking around the area and eventually you will see one. Once you’ve found one, start attacking it, and once the nightwing is weaker, throw your pal sphere to catch it, then head back to your base.
Now, there are basically three things you need to fly a nightwing. Firstly, you need to reach level 15 to unlock the nightwing saddle. Secondly, you need to build your Pal Gear Station, which can be done at level 6. Finally, go to your Pal Gear Station and look for the nightwing saddle.
There are quite a few materials you need, as you can see here, but they are all pretty easy to obtain. Once the work is done and you have your nightwing saddle, simply summon it, then hold F to mount it. Follow the button guide at the bottom of your screen to fly the nightwing in Palworld.
If you you want to see the full video guide on how to fly on nightwing in Palworld, click on the video below:
