Palworld – How to Move Base – Quick Guide
Wazzup Everyone, Welcome back to another video guide on how to move base in Palworld.
The first crucial step is to ensure that your Palworld base is upgraded to at least level 10, unlocking the option for a second base. To check the upgrade information, navigate to your PAL BOX and press the “V” key on your keyboard to access the upgrade screen. Look for the indication at the bottom that shows you can build up to 2 bases in Palworld.
Moving on to the second step, press “B” on your keyboard and hover over the PAL section, locate the palbox, and build one.
Then, navigate to the storage option and construct several of these wooden storage boxes. Try placing them close enough to your palbox, that way you can speed up the process.
Once you have enough storage boxes, head to your palbox and press “C” to fast travel to your original base and initiate its dismantling. Upon arrival, to start disassembling your things, press “B” on your keyboard to open up the build menu, followed by “C” to enable disassembly mode—proceed to disassemble everything. All resources used will be returned to you.
Now, transfer all the items to your inventory, but be mindful of your weight limit. Avoid overloading your character and, once you reach the weight limit, fast travel back to your new base. Begin placing items, paying special attention to heavy ones like rocks and woods, into the storage boxes you’ve built. Repeat this process until all your possessions have been successfully relocated.
Click on the video below to see the full guide!
